Changed Air Filter-No problem
https://www.chevyhhr.net/forums/maintenance-upkeep-50/checking-replacing-air-filter-10757/
Well I finally got around to changing the filter a while ago using "Black Rose" thread.
Just like he shows it. Took me 30minutes from start to finish and no problems.
Pull out the air intake from the fender-no sweat.
Disconnect the top of that tube from under the fairing using an 8mm socket or a screwdriver which I did.
Disconnect that electrical thing under the fairing
Pop the back side of the fairing off the grommets that hold it down.
Flip it over and there are all the torx screws
Take them out and there's the filter.
Whole process is much easier than it looks.
Thanks all.
Thanks all.
https://www.chevyhhr.net/forums/showthread.php?t=10757
Thanks all.
Thanks all.
To put the unit back into the three grommets I slobbered soapy water over them to give it some sliptivity. With this help I did not even feel the two back ones snap into place. (Also used soap on the hose out of te filter.)
