Chasing a noise...
Old 12-14-2021 | 09:42 AM
SwaintaN's Avatar
Donor hhr in back yard, pulled rim/tire off of it. I didn't replace driver side though.
Old 12-14-2021 | 09:49 AM
If it was enough force to tear the wheel off, then any part of the suspension is suspect to have damage. Even the unibody may be "tweaked" and out of spec.
I would say it needs to go to a body shop and be measured and checked for damage on a jig machine.
Old 12-14-2021 | 09:53 AM
SwaintaN's Avatar
I'll be 100% honest, I didn't even think of that. I'll get it back up in the air and check that this weekend.
Old 10-15-2023 | 09:53 PM
SwaintaN's Avatar
I ended up ripping off the lca on both sides, putting in new ones and new lca rear bolts, tighten the nuts on top of shocks.
What really sucks, the weld nut on passenger rear, came in welded. Had to rip off the the cage, and cut the weld nut off. Ended up having to cut a small hole inside the car, right above the lca bolt to do it. Rewelded what I cut, painted put carpet back.
Instead of weld nut and cage, it's now welded metal plate and grade 10 lock nut
hwmonkey
11-12-2018 10:28 AM
papa_jo
08-18-2018 10:09 AM
flstss
11
10-03-2017 11:00 PM
badandy519
08-28-2013 02:18 AM
badassbowtie
05-21-2012 05:09 PM
