cheap fix/cup holder
This is a good fix. Go to Wal-M / K mart...
buy the Roadmaster 16oz travel mug / take the mug to where you buy O-rings
for water filters/ get some velcro/ pull the rubber cup holder liner out of the
base/ tape the velcro to the base & the other velcro to the mug /put the base back/put the O-rings (I used two for each cup) on the cup from the bottom just enough that they are almost tight/ now let the O-rings center
the cup as you push it into place. Done !
This helps you with the reach. It will take a 12oz soda/pop can your your
fountain drinks (no big gulp) & for you speed-heads yes your STARBUCKS.
try it out.
later rNr // mike
try it out.
later rNr // mike
It's simple:
Buy a big travel mug.
Put O-rings around the bottom of the mug.
Put Velcro on the base of the mug and bottom of cupholder.
Place the mug in the cupholder. The Velcro and the O-rings will hold it in place so you can use it as a raised cupholder.
Only problem is that it won't hold my insulated coffee mug with the handle.
It's simple:
LATER rNr// mike
