cheap fix/cup holder
Old 04-11-2007, 10:04 AM
rockNroad's Avatar
Lightbulb cheap fix/cup holder
This is a good fix. Go to Wal-M / K mart...
buy the Roadmaster 16oz travel mug / take the mug to where you buy O-rings
for water filters/ get some velcro/ pull the rubber cup holder liner out of the
base/ tape the velcro to the base & the other velcro to the mug /put the base back/put the O-rings (I used two for each cup) on the cup from the bottom just enough that they are almost tight/ now let the O-rings center
the cup as you push it into place. Done !
This helps you with the reach. It will take a 12oz soda/pop can your your
fountain drinks (no big gulp) & for you speed-heads yes your STARBUCKS.
try it out.
later rNr // mike
rockNroad is offline
Old 04-11-2007, 11:48 AM
solman98's Avatar
DO you have a pic? That might help me figure out what you did exactly.....
solman98 is offline
Old 04-11-2007, 11:49 AM
Better Patent that Idea
HillsdaleHHR is offline
Old 04-11-2007, 11:50 AM
dbarberaz's Avatar
Thanks
dbarberaz is offline
Old 04-11-2007, 12:16 PM
Goose's Avatar
Thanks
Ditto..having a hard time picturing this..need a visual aid
Goose
Goose is offline
Old 04-11-2007, 12:18 PM
JESSE's Avatar
Cant visualize that one!
JESSE is offline
Old 04-11-2007, 01:00 PM
rockNroad's Avatar
This weekend I'll take pics
later rNr // mike
Old 04-11-2007, 04:50 PM
hhrcrafty's Avatar
It's simple:
Buy a big travel mug.
Put O-rings around the bottom of the mug.
Put Velcro on the base of the mug and bottom of cupholder.
Place the mug in the cupholder. The Velcro and the O-rings will hold it in place so you can use it as a raised cupholder.
Only problem is that it won't hold my insulated coffee mug with the handle.
hhrcrafty is offline
Old 04-11-2007, 05:50 PM
Black Beauty's Avatar
Is this gonna be called the "rockNroad cup holder" mod ?
Black Beauty is offline
Old 04-11-2007, 07:21 PM
rockNroad's Avatar
Originally Posted by hhrcrafty
It's simple:
You got it HH !
LATER rNr// mike
Quick Reply: cheap fix/cup holder
