Check Engine Light - Code P0128 - Will it pass Emissions?
Old 02-20-2020 | 02:50 PM
Well , I’m out, I already suggested and advised you, I can’t find a $20.00 AC Delco 131-158 thermostat listed at O’Reilly’s for under $50.00.
https://www.rockauto.com/en/catalog/...hermostat,2200
its cheaper from RockAuto and then there’s the discount.
Old 02-20-2020 | 03:39 PM
Cat Man HHR's Avatar
Blue I'm with you about bailing out.
I too posted the link for the thermostat but not in picture form. (line #10)
Even answered her question about inspection in her state ( line #10)
Old 02-20-2020 | 05:54 PM
$165 labor is outrageous!!!! 2 bolts and a good back. 10 minutes.
The flat rate is listed at 1.2 hours, I guess they are including a pack of cigs and a few cups of coffee.
Old 02-20-2020 | 06:13 PM
As stated many times before on this site, it's the only one that works for the HHR. Go with the off brand, cheaper ones and you're asking for problems.
#131-158 only.
Old 02-22-2020 | 08:38 PM
Radco's Avatar
SO the AC Delco is the ONLY way to go ? The others do not last or just do not work ? I am curious now lol...Would have never though that would be the case !!! Thanks
Old 02-22-2020 | 08:51 PM
They don't work... It's a timing thing with the computer.
Old 02-22-2020 | 09:48 PM
Do it once & the right way. This will cost much less than having to have it redone due to aftermarket T-stat.
Old 02-22-2020 | 09:54 PM
The inner seal is different and does not tend to unravel and hold the valve open.
Old 02-23-2020 | 07:49 AM
Radco's Avatar
Thank You for the reply ! I do not need to change mine yet but you all got my curiosity up when I read this thread :) I rather pay more once then pay less 3 or 4 times :O Great info Thanks again
Old 02-23-2020 | 08:44 AM
Trust me, I learned the hard way, two Stant, one purchased , one warranty, one MotoRad , still had code P0128 after a few days to a week, then AC Delco, problem solved, and no problems since 2012 and a lot of miles , like 150,000 on Oldblue.
