Chevy HHR 2006, Key Cannot Be Removed, Stuck On
To get the key out ,look under the steering column and remove the little pop out cover . In there you will see a white button or pin , at the end of a switch that is laying on its side. Push the pin- button in and this will let the key turn and be removed.
terrycon
08-08-2016 08:52 AM
majic1984
01-23-2014 07:06 AM
