Clutch go down, don't engage and liking on reservoir brake
Old 08-13-2022, 12:51 PM
  #61
On the clutch fluid line at the slave cylinder end
That’s the bleeder there
A little closer look
Oldblue is online now
Old 08-13-2022, 03:03 PM
  #62
tomasorta's Avatar
so I have to conect the vaccuum to tha bleeder and is the same for brake? or is another procedure differnt for that?
tomasorta is offline
Old 08-13-2022, 04:09 PM
  #63
Connect the vacuum to that bleeder, same process as for brakes, check the brake master cylinder reservoir so you don’t run low on fluid.
Old 08-14-2022, 09:11 AM
  #64
Or, the old fashioned way, with a lovely assistant pressing on the pedal.
donbrew is offline
Old 08-15-2022, 12:45 PM
  #65
tomasorta's Avatar
Yesterday I did, and it was ok, yes similar to the same procedure for brakes, thanks so much to everyone helping me in this thread, I really appreciate that... today I will work with the brake, I want to replace the rubber for one of the left front calipers I saw the rubber in the calliper cylinder is a little burn.
Old 08-15-2022, 01:20 PM
  #66
RJ_RS_SS_350 is offline
Old 08-15-2022, 01:22 PM
  #67
Awesome news, it’s fixed!
I always suggest replacing the front callipers in pairs and the flex hoses , they are the same age! Those copper washers to, never reuse them or the banjo bolts!
Old 08-15-2022, 02:29 PM
  #68
tomasorta's Avatar
I replaced both in 2018 I think, but the rubber in the left I saw a little burn on one side so to avoid any issues I will replace the rubber only, the brakes, and the cylinder are news, because I, when I bought in 2018, was in CAPS brand new calipers.
DangerBoy
Drivetrain (Excluding Engine)
10
10-02-2014 08:18 PM
redmom605
08-04-2014 06:55 AM
Wolfblitz
06-24-2014 12:45 PM
ouhockeyplayer
10-04-2009 08:40 PM
ghrtfldr
04-07-2008 03:28 PM
Quick Reply: Clutch go down, don't engage and liking on reservoir brake
