Coolant temp.
Old 06-19-2022, 12:09 PM
Gearhead1's Avatar
Originally Posted by Oldblue
Gates, AC Delco , use new gear clamps the upper hose between the rad cap and cylinder head is a cut to fit piece. I should have cut a piece out of the lower hose that was like new!
Huh? Lol. ….must be Canadian vs Southern Redneck terminology…lol.
…new gear clamps? Do you mean like new hoses clamps with screw/ thread slots? If so I like to use the stainless steel ones.
Gearhead1 is offline
Old 06-19-2022, 03:32 PM
Or correct names and Southern Redneck terminology…lol.
donbrew is offline
Old 06-19-2022, 03:35 PM
Yes, hose clamps , the ones with the worm gear !
Oldblue is offline
Old 06-19-2022, 06:12 PM
Gearhead1's Avatar
I thought that was what you meant. Other than spring clamps, those were all that I knew off
Old 06-20-2022, 06:44 AM
Me too, and I was taught to not reuse spring clamps, no particular reason.
Oldblue is offline
Old 06-20-2022, 10:42 AM
greg8453's Avatar
Oh there's a reason. They are a PITA.
greg8453 is offline
Old 06-20-2022, 03:03 PM
They're easy with the #80 tool;
donbrew is offline
Old 06-20-2022, 03:12 PM
These are like my hose spring clamp pliers, they worked great.
Oldblue is offline
Old 06-20-2022, 03:43 PM
greg8453's Avatar
So long as you can get the jaws on the ends you are good to go. The only other problem, and it can be a bear is when the hose is swelled.
greg8453 is offline
Old 06-30-2022, 09:39 AM
Gearhead1's Avatar
Hose spring clamp tool
They also make a tool that the jaws are at end of a cable to get to the impossible places regular plier handles wont work in
Quick Reply: Coolant temp.
