which coolant temp sensor to use?
Old 07-11-2020 | 04:50 PM
comandoed's Avatar
What is the recommended ACDelco Coolant Temperature Sensor to use on 2007 HHR LT?
My mechanic is going to replace thermostat and temp sensor.
found
ACDelco 131-158 Gm Original Equipment Thermostat
ACDelco 213-4514 Professional Engine Coolant Temperature Sensor
ACDelco 213-4333 GM Original Equipment Sensor (use together with mating connector PT1798)
thanks
Old 07-11-2020 | 06:52 PM
The 213-4514 doesn’t require the adapter harness, I would use that, my question is why replace the sensor , not common that they fail, a P0128 code points to the thermostat which you state the correct part.
Old 07-11-2020 | 07:19 PM
comandoed's Avatar
I also think the sensor replacement is questionable from what I have gathered.
But since it's not terribly expensive and since he will charge me the same if I replace it or not I'll just do so.
Also my car is pretty old and probably could use the new part.
I'll just go ahead and get the part # you indicated.
thaks
Old 07-12-2020 | 07:44 AM
Your welcome, the thermostat is easy to change just 2 , 10mm bolts
https://www.chevyhhr.net/forums/www....ad.php?t=24493
ironheadbro
03-06-2020 08:00 AM
quick66ss1
10-24-2015 08:42 PM
lw9090
10-05-2015 01:21 PM
Me and my monkee
Maintenance and Upkeep
13
07-19-2014 06:57 PM
dinobass
11-20-2006 03:18 PM
Quick Reply: which coolant temp sensor to use?
