cooling fan runs always
Old 01-16-2022, 10:24 PM
MN Murph's Avatar
I will plug back in the relay, clear the codes, and then recheck.
How about to simplify, I'll plug back in the relay for the cool fan. Then drive it till it throws a CEL again.
The crankshaft relearn is a must right? It's not like the new ecm/ecu learned it without a tech2 put to it, right?
MN Murph is offline
Old 01-17-2022, 06:30 AM
Right, unless it was deleted.
Oldblue is offline
Old 01-17-2022, 11:39 AM
MN Murph's Avatar
Finding a shop with tech2? For crankshaft relearn
I did disconnect the battery a few times after replacing the ecm/ecu. Codes have been deleted that way. So, gotta do that crankshaft relearn anyway, right? For doing crankshaft relearn:
  • I called one shop and the fella said $250, because they're gonna call in a tech service to come out to their shop and do it.
  • How much would dealership charge? Seems like it should be closer to $75.
  • I just moved and our good family mechanic's shop burnt down, he's done/retired and gone back to farming and being retired. So how to find a good mechanic with tech2? Just call around?
MN Murph is offline
Old 01-17-2022, 12:08 PM
GM usually charges 1 hour labor. Your telephone will help you more than someone in Virginia.
donbrew is offline
Old 07-18-2022, 02:36 PM
MN Murph's Avatar
Radiator fan runs continuously, and no ac/clutch
Alright, so... fan still runs continuously, no ac, no ac clutch engaging.
  • Replaced the dexcool, thermostat(131-158), and ect sensor.
  • (Also, maybe unrelated, got the crankshaft relearned at dealer to follow-up ECM replacement after P0606 (internal fault in ECM))
MN Murph is offline
Old 07-18-2022, 05:20 PM
You already replaced the BCM and ECT, that narrows it down to:
* stuck relay?
* somebody thought they were smarter than the designer?
* maybe the wire to the ECM is shorted.
not much else.
donbrew is offline
jasguer
11-16-2021 08:04 PM
aradmahogany
Maintenance and Upkeep
11
08-06-2018 02:39 PM
rwatkins
25
08-03-2016 09:49 AM
cturboaddict
08-18-2013 09:15 PM
oms
05-20-2011 01:54 PM
Quick Reply: cooling fan runs always
