Cut my wires!!!!
Cut my wires!!!!
A couple months back I plugged in a converter box to my cigarette lighter outlet
the wires crossed and melted all the way up to the fuse box
so I took off the dash and I cut the wires now I don't know where to connect them back to
I bought a new harness
But it's also cut
I thought it would be as easy as just attach color to color
It's not
now I need to go directly from the battery
all the way through the car
to under the hood
What is that called?
Is it the engine wire harness?
cuz all the ones I found don't go all the way back to the battery
But it's also cut
It's not
to under the hood
Last edited by Mike Talmadge; 09-06-2019 at 07:08 AM. Reason: A lot of misspelled words
What does back to the battery have to do with that? I don't know how other wires could be involved. Why can't you do color to color end to end? You have the harness; remove the wire you need and replace the the burned one.
There is one wire from the fuse box to the battery.
I am so confused!
I am so confused!
Cut my wires!!!!
Hey guys some of you may know that I cut the wires to my wire harness inside of my 07 HHR
well I went to a Pick-n-Pull and got a harness for my mechanic and it's the wrong one it won't fit into the computer so apparently I need the wire harness to a
07 2.4 l LT with electric seats seat warmers and a moonroof and I cannot find any in Texas not a single one I don't know what to do
