Dash Bezel
Old 06-30-2022, 09:26 AM
Gearhead1's Avatar
Dash Bezel
Suggestion….I want to put some USB charging ports in the plastic dash bezel. How much space in behind the lower section? The longest (dual usb) is 59mm. Though really rather have a single in each lower corner.
Thinking….for the dual maybe. Left and right for singles.
Single.
Another dual configuration…
Dual….59mm long.
Gearhead1 is offline
Old 06-30-2022, 09:28 AM
Gearhead1's Avatar
Also…suggestions on mounting these things securely
Old 06-30-2022, 11:07 AM
Looks like an open space in the centre, under the HVAC controls, just have to be sure there’s still room for the power outlet and rear wiper switch
Oldblue is online now
Old 06-30-2022, 11:17 AM
Gearhead1's Avatar
guess I need to remove it and do some measuring stuff
Originally Posted by Oldblue;
[img
https://cimg9.ibsrv.net/gimg/www.chevyhhr.net-vbulletin/768x1024/5d4eaf82_9853_47bf_905d_6b90e9eeece5_a93ca7a5e3bfe e1394683e67f951845c499b9142.jpeg[/img]
Old 06-30-2022, 11:21 AM
Gearhead1's Avatar
Is there a good point to power these from the fuse box on right side of the console?
I suggest finding an outlet that is made for the job. The pics you show are usb ports that are to be soldered to a main circuit board.
Something like these=
firemangeorge is offline
Old 06-30-2022, 11:26 AM
Gearhead1's Avatar
I saw some those…and one I ready liked is designed to fit in rocker switch slot….but having rook for them is my issue. The type that plug into cig. Lighter is out cause I use that for GPS.
Old 06-30-2022, 11:47 AM
PulpFriction's Avatar
It pops right off. Don’t be too afraid of it. Go in and have look. There are probably a youtubes on radio replacement that will give you some reassurance.
PulpFriction is offline
Old 06-30-2022, 12:01 PM
This is what I got, gives you options.
https://smile.amazon.com/gp/aw/d/B00...b_b_asin_title
RJ_RS_SS_350 is offline
Old 06-30-2022, 12:02 PM
Stick fingers in AC vents, yank. Real involved requires highly trained technician.
Back space is not your problem. the attachment pins take up all of the edge space.
Any of the fuse positions labelled "spare" are hooked up to the RAP relay (like the radio and windows). I think the ones labelled "empty" are live, not sure.
The 12 v power outlet (cig lighter) is within 3 inches, problem? Do you use it? Get the dual usb replacement.
donbrew is offline
Quick Reply: Dash Bezel
