Dash Bezel
Dash Bezel
Suggestion….I want to put some USB charging ports in the plastic dash bezel. How much space in behind the lower section? The longest (dual usb) is 59mm. Though really rather have a single in each lower corner.
Thinking….for the dual maybe. Left and right for singles.
Single.
Another dual configuration…
Dual….59mm long.
Single.
Dual….59mm long.
guess I need to remove it and do some measuring stuff
Originally Posted by Oldblue;
[img
[img
https://cimg9.ibsrv.net/gimg/www.chevyhhr.net-vbulletin/768x1024/5d4eaf82_9853_47bf_905d_6b90e9eeece5_a93ca7a5e3bfe e1394683e67f951845c499b9142.jpeg[/img]
Looks like an open space in the centre, under the HVAC controls, just have to be sure there’s still room for the power outlet and rear wiper switch
Stick fingers in AC vents, yank. Real involved requires highly trained technician.
Back space is not your problem. the attachment pins take up all of the edge space.
Any of the fuse positions labelled "spare" are hooked up to the RAP relay (like the radio and windows). I think the ones labelled "empty" are live, not sure.
The 12 v power outlet (cig lighter) is within 3 inches, problem? Do you use it? Get the dual usb replacement.
