Dash Bezel
Old 08-10-2022, 04:28 PM
Gearhead1's Avatar
USB ports added: update
I got my USB ports installed and all is doing well. I back pinned large red wire to supply what little power they required (6 amps max.) I made a staple out of a larger paper clip soldered my wire to staple and wedged it in good between the wire insulation and the crimped end….
inline fuse then thru switch so can turn on…(same switch I used for when Im towing it, so can turn off and wont drain battery)….fused also.
Gearhead1 is offline
Old 08-10-2022, 04:33 PM
Nice job!
Oldblue is online now
Old 08-10-2022, 05:01 PM
Are you using a paper clip as a conductor?
RJ_RS_SS_350 is offline
Old 08-10-2022, 05:44 PM
PulpFriction's Avatar
I was going to say, no worries, paper clips are made from zinc-plated steel wire. (The plating would make it easy to solder.) But then I decided to double check and discovered these surprising facts, courtesy of Quota.:
They’ll be fine until the fire starts.
PulpFriction is offline
Old 08-10-2022, 06:03 PM
I would try to steer away from splicing into the main battery feed. Too many chances for unintended consequences. Your house, your fire.
3 threads merged.
donbrew is offline
Old 08-10-2022, 06:19 PM
  #26
Gearhead1's Avatar
I was going to say, no worries, paper clips are made from zinc-plated steel wire. (The plating would make it easy to solder.) Bu t then I decided to double check and discovered these surprising fact, courtesy of Quota.:
I’ll be fine until the fire starts.
not sure what kind of clips they are talking about but these are definitely metal….and what appeared to be chrome plated…very shiny anyway, which I scrapped off in the area I needed to solder to.
Old 08-10-2022, 06:27 PM
  #27
Gearhead1's Avatar
3 threads merged.
I understand. I feel like I have done it in a safe manner….I didnt butcher up the wiring…didnt even cut and splice a wire…everything is fused…the usb’s themselves dont hardly draw any power…3 amps per port x 2 (2 of them). More power than that from static discharge…lol
Old 08-10-2022, 06:29 PM
  #28
Jit
"How To" Tutorial Library
01-22-2020 01:07 PM
dandhcomputers
12
05-23-2008 09:38 PM
MWG2
01-13-2008 12:33 AM
snova031
14
03-28-2006 06:05 PM
Quick Reply: Dash Bezel
