Dash lights intermitent
Old 02-07-2022, 05:18 PM
OKIE SS's Avatar
2008 HHR SS - Often when I start the car the dash lights do not come on. I get the warning indicators before I start the car but, often, the rest of the dash lights will not come on when the car is started; no DIC information and no radio lights even if I turn the radio on. Often, when I start the car in the garage, lights are fine but as soon as I back out of the garage, they'll go out - not all the time but often. When they are off, they may stay off the rest of my driving trip or may suddenly come back on. Doesn't matter if it's daytime or nighttime. The dash light dimmer has no effect when they're not on but will dim/bright when they are on.
Lately, my trips have been very short shopping or running errands so I don't consider the issue to be that critical but would like to find out why it happens. Any ideas?
OKIE SS is offline
Old 02-07-2022, 06:57 PM
Where is the dash light dimmer switch in it’s position? That switch on the left of the fog light, TC switch.
Not an SS but there to the left of the fog light switch
Oldblue is offline
Old 02-07-2022, 07:49 PM
Do you keep things on top of the dash, covering the little bubble? In other words; do the DRLs work?
donbrew is offline
Old 02-07-2022, 08:11 PM
OKIE SS's Avatar
As I noted, " The dash light dimmer has no effect when they're not on but will dim/bright when they are on." It has no effect when there are no lights, it works as it should when there are lights.
Nothing is on top of the dash, DRLs work as they should.
OKIE SS is offline
Old 02-07-2022, 09:33 PM
Probably the dimmer switch then.
donbrew is offline
Old 02-07-2022, 09:34 PM
Sounds like a loose connection, maybe behind the dash, or at the dimmer.
RJ_RS_SS_350 is offline
Old 02-08-2022, 07:23 AM
Apparently the dimmer switch works as it should.
Oldblue is offline
Old 02-08-2022, 09:05 AM
When it works it works. If the wiper inside is mangled it will be intermittent.
donbrew is offline
Old 02-10-2022, 08:08 AM
OKIE SS's Avatar
'...wiper...'?
OKIE SS is offline
Old 02-10-2022, 08:25 AM
It is a variable resistor with a wiper (the part that moves).
donbrew is offline
Quick Reply: Dash lights intermitent
