daytime running light options
I have noticed on other HHRs that only the parking lights are lit as they drive. On my 2007 HHR only my headlights light as my daytime running lights, unless I turn off the auto light option. I would prefer only the parking lights during the daylight hours but do not know if it requires a different module or procedure to turn off the headlights during the daytime and automatically illuminate the parking lights for my dtrls.
This is from the GM repair manuals.
Here's how they did it in 2006:
The ambient light sensor is a light sensitive transistor that varies its voltage signal to the body control module (BCM) in response to changes to the outside (ambient) light level. When the BCM receives this signal, it will either turn ON the daytime running lamps (DRL) or the headlights if the headlamp switch is in the AUTO position. Any function or condition that turns ON the headlights will cancel the DRL operation. With the headlight switch in the AUTO position, the headlights will either be turned ON or OFF, after an approximate 30-second delay depending on whether daylight or low light conditions are sensed. The DRL illuminates the park/turn signal and DRL lamps. The DRL will operate when the ignition switch is in the ON position, the gear selector is not in the PARK position, and the parking brake is released. When these conditions have been met and the ambient light sensor indicates daytime conditions, the DRL will illuminate.
DRL operation in manual transmission equipped vehicles will occur when the ignition switch is in the ON position, and the parking brake is released.
And here is how they do it now (2007-2008):
The ambient light sensor is used to monitor outside lighting conditions. The ambient light sensor provides a voltage signal that will vary between 0.2 and 4.9 volts depending on outside lighting conditions. The body control module (BCM) provides a low reference ground and 5-volt reference signal to the ambient light sensor. The BCM monitors the ambient light sensor signal circuit to determine if outside lighting conditions are correct for either daytime running lights (DRL) or automatic lamp control (ALC) when the headlamp switch is in the AUTO position. In daylight conditions the BCM will apply ground to the DRL relay control circuit causing the DRL relay coil to energize. With the DRL relay energized, the switch contacts close allowing battery voltage to flow through the DRL fuse via the DRL control circuit illuminating the low beam headlamps at reduced intensity. The DRL control circuit that supplies the low beam headlamp fuses with voltage contains a loop of wire that acts as resistance. This resistance is responsible for the low beam headlamps illuminating at a reduced intensity. Any function or condition that turns on the headlamps will cancel DRL operation.
Chad, look at the two descriptions above and tell me if you want to tackle that re-wire. Is it sure fire? Nothing in life is. But if you want the schematics to each system I can supply you with it.
See this is why your THE MAN Mr chevymgr i just figured it was a ecm reprogram. Ill stick with my Headlight DRLs.
