daytime running light options
I modified the DRL relay and turned mine off completely. I've turned these off on every GM car I have owned since 1995. Remove the relay from the relay center (it's under the hood on the left side near the master cylinder) when you look at it from the top make sure the writing on it is right side up. Bend or remove the upper right prong. reinstall the relay. This works for sure on automatic trans cars. Never done it to a manual trans car.
Later Al
Later Al
Bringing back an old thread, on my SS I just removed fuse #31 from the fuse box under the hood and my DRL's don't turn on anymore. The DIC still shows them as being on but with the fuse removed they won't turn on.
#27
It sounds like it would be a simple rewiring of the DRL Module output from the headlamps to the park/turn signal lamps. ChevyMgr could you send me the schematics to each system? I would be interested to see what would be involved.
Thanks,
JJ
Thanks,
JJ
#28
#29
