Dedicated turn signals
Old 12-05-2020 | 10:17 PM
hhrumadbruh's Avatar
Hello everyone.
Today I ventured into trying to do this myself.
I managed to tap into the green wire on the right side, which is on the 3 wire plug for the tail light
This allowed me to have hazards and turn signals on the reverse light (which I plan to change to an amber/orange LED)
However, the brake lights still connect to this wire.
I was thinking about tapping into the front parking/blinker light wires and running 2 wires to the back with a relay, since the front orange/amber lights are not connected to anything other than hazard/blinkers
Is there another way to go about this?
I read somewhere that the blinkers are connected/controlled in the BCM/computer. I doubt there is a way to change the setup easily. Unless the 2010 actually has a relay or 2 that I can access/modify?
Old 12-06-2020 | 09:20 AM
Lonwane's Avatar
Here's what I did when I went to the 4 red light rear.
The bottom 2 I connected to the 3rd brake light and tail light wiring so there are tail and brake lights.
The top 2 I left alone so there are tail, brake and turn lights.
Old 12-06-2020 | 09:42 AM
The Stop-Turn lights are controlled on 1 wire by the BCM. The CHMSL is on a separate circuit.
You of course, are planning to install some sort of back up light, since they are not a "suggestion".
kwe45919
02-01-2021 03:11 AM
redlee73
Mods - Exterior
04-21-2015 09:35 AM
spideroneil
Mods - Exterior
13
12-10-2014 09:40 PM
psychowpns
10-10-2013 09:29 PM
Thetaxi
06-17-2008 07:17 PM
