Disarming traction control on 2007 hhr 2.4l
Old 02-13-2011 | 12:58 AM
EnglishRacing's Avatar
I have a 2007 HHR 2.4L. i'm going to turbocharge. My problem is with the traction control. it's only disarmed in low1. low 2 and drive it automatically turns on. if applying 300hp the wheels tend to spin in second,then tc kills the throttle until a wheel hooks up. this i find dangerous. is there a fix for this?
gary english
englishracing@yahoo.com
Old 02-13-2011 | 06:27 AM
When you find a solution, let me know.......
Seriously though, I've thought about this but haven't looked into it yet. The "other way" to shut off traction control is by setting the E-brake...... There's got to be a switch somewhere in the E-brake system doing this........ What about replicating that switch with a dash-mounted switch. Seems feasible, but as I said I haven't ripped anything apart yet.
Old 02-13-2011 | 12:00 PM
Laco's Avatar
I suspect if you use a switch to simulate setting the E-brake, you will be stuck with that E-brake/Parking brake on, message on the DIC.
Old 02-13-2011 | 01:57 PM
That would depend on how the switches are setup, I've not pulled my console so I don't know what's there. On the '07 there's no "parking brake" message.... just the red "brake" message which would also come on for brake failure...... T/C could be on a different switch.
Old 02-13-2011 | 02:59 PM
IgottaWoody's Avatar
Parking brake wil also negate the brake control is so equipped....(ABS)
Old 02-14-2011 | 09:25 PM
Laco's Avatar
My 07 most definately has a parking brake on message on the DIC, and mine was manufactured, I believe in December of 06.
Old 02-15-2011 | 09:51 AM
JoeR's Avatar
gary english
Well, if you're going turbo, you definitely need a tune. If using HPTuners, traction control can be toned down or eliminated entirely in the tune.
Old 02-15-2011 | 10:34 AM
diskullman's Avatar
There is a fix ...possibly
http://www.easyperformance.com/Auto_..._TCS_Desc.html
This sets your default TC OFF.
I have one if you wan't to experiment, you probably have to study how it will fit to the HHR's wiring harness.
Old 02-19-2011 | 11:48 AM
Someone local mentioned taking it to a race car tuner and possibly have them turn it off in the computer,but I havent called anyone yet to see about it! i guess in 08 they figured out they needed a button with the SS model coming out.. Also TC is off in Low 1, so theres a swith on the shifter too evidently.
Old 02-19-2011 | 11:54 AM
On the shifter or in the tranny..... hopefully it's at the shifter. I think the manual version has a switch. Personally I want a switch and not have it tuned out completely, but that's me.....
