Do Stock HHRs Have an Anti-Sway Bar?
Old 11-17-2008, 05:46 PM
SandyBeach's Avatar
I have 1LT and added the anti-sway bar and love it! Does the "sport suspension" on the 2LT offer it? I'm considering purchasing a new one and need to know if I will have to buy a new one for the new vehicle.
SandyBeach is offline
Old 11-17-2008, 06:04 PM
twistrman's Avatar
It does not have the additional rear anti sway bar. I just added one to my 2LT this past weekend. People have added them to the SS as well.
As far as i know the only difference in the sport suspension is the struts and the shocks (or maybe not the shocks)
so, yes, you will have to buy a new one
twistrman is offline
Old 11-17-2008, 06:23 PM
hyperv6's Avatar
The LS and LT do not have a rear bar.
The SS comes with a rear bar.
Some add a aftermarket bar to replace the stock rear bar on the SS. They claim it is better but I have not seen any numbers to show how much improvment there really is.
hyperv6 is offline
Old 11-17-2008, 07:27 PM
oneton's Avatar
Why not take it off before you trade? You put it on so take it off and put it on the new 2Lt
oneton is offline
Old 11-17-2008, 07:28 PM
allsteelers's Avatar
The SS does not come with a rear sway bar stock. I own an SS and just installed a rear sway bar. The SS suspension is very tight but has a little too much initial body lean when entering turns. The sway bar really helps keeps the car flat.
allsteelers is offline
Old 11-17-2008, 07:52 PM
saltyfishguy's Avatar
X 2
saltyfishguy is offline
Old 11-17-2008, 08:17 PM
Rcflyboy's Avatar
X3. only takes 15 min to take it off. Save yourself the money.
Rcflyboy is offline
Old 11-17-2008, 09:08 PM
Yonash's Avatar
precisely. i just put one on my SS as well, and i didn't take anything off to put mine on.
Yonash is offline
Old 11-17-2008, 09:10 PM
hyperv6's Avatar
Better tell GM it has none as they list the rear suspension as
Rear: semi-independent torsion beam with montoube gas shocks; 24mm solid stabilizer bar
Check out GMs specs and they all list the SS with a 23 MM front and a 24 MM rear stabilizer bars.
At least that is what is on my SS.
Note the bars is not a bolt on as the one your installing. It is the bar on the underside of the Torsion Beam the runs accross the beam. It is tied inside the ams on the ends of each side.
You don't have to remove it as it is out of the way.
The truth is if you add a bar your running two bars on the back. The second just increases the rate over the stock one.
Keep in mind all bars do not look alike but do pretty much the same job even thought they are designed differently from the norm we are used to.
hyperv6 is offline
Old 11-18-2008, 02:02 AM
IgottaWoody's Avatar
All HHR's have this bar,but not of the same diameter.Its more of a torque tube attached between the two swing arm pivot points.Helps add rigidity to the cross beam(takes the flex out).Otherwise if it was a true Sway bar,you'd have over 50mm of bar on the back(including the added sway bar) compared to the 23 on the front.Imagine what That would do to controllability! I believe Chevy just uses it as a marketing tool.Other then skid pad numbers its all in the feel or track time to "see" what it really does to handling. It does work and I'd hate to say it but I'm beginning to think it could use an even bigger bar with a comparable bar on the front..its a short narrow car but with a high CG,so she still rolls a bit.But thats me,I prefer a tighter car,though don't take it as a complaint.Its a great stock handling car!
IgottaWoody is offline
Quick Reply: Do Stock HHRs Have an Anti-Sway Bar?
