Do you let your hhr warm up?
For Sure especially when the temp is below 40 degrees F.
Idle for about 3 minutes then easy throttle for about 3 miles, then normal driving unless some AbNormal Nut tail gates me.
Most of the HHR's I have owned have a little lite rattle/knock noise with any pedal pressure until they warm up .... then gone..
Silverfox
Silverfox
Here in NorCal start and go is my routine.
However I am searching for a vacuum leak or a cause of rough idle when starting.
Replace air filter cleaned throttle plate and MAF.
When in Oregon few weeks back was very rough start at below 28 degrees and frozen and had to feather throttle a bit to keep it going first 30 seconds.
Check plugs next.
my climate control door is still flapping on start as well. Search on that reveals the procedures Thanks
Check plugs next.
