Dome lights
Pretty sure that got discussed a couple years ago. If I remember correctly, the answer was No.
They will "time out" on their own if you leave a door open with the engine off. Something like 10 mins. or so, then the battery saver mode kicks in.
Thats what I thought. Reason for my question is, I shut the door last night and the dome lights did not go off. After going back into the dark garage 30 min later I found them on. After shutting the drivers door a few times it went out. I can not believe GM did not put a OFF override switch for the dome lights.
