door handles on 07 panel?
Just go to the junk yard and find some door pulls that you like and get them. Save the bolts or screws that held them on and get some new wellnuts that match the thread of the bolts or screws and put them on your doors. There should a few places to install the wellnuts on the metal door frame
If I understand the question correctly you're trying to get some kind of door pull for the inside of the door to make it easier for passengers in your new rear seat to close the door right? I agree with the others about buying trim panels from windowed doors, though I have no idea why you'd have to cut them. I'd think you'd probably want to make something to fill the hole where the window would normally go so that they're not staring at painted metal. otherwise wouldn't the interior panel just fit into place the same way it would if the door had a window?
