Door lock malfunction
Old 11-18-2018 | 08:37 PM
peterdulux's Avatar
https://www.rockauto.com/en/moreinfo...441020&jsn=572
Having a door lock actuator issue.
If I lock the doors with the door lock switch, i can't open drivers door with the key. If I lock drivers door from outside with the key, I can unlock the door.
This is indicating to me that when locked from the door lock switch inside the car, it activates the actuator causing it to malfunction to the point where the door can not be unlocked with the key.
Locking from the outside with the key, does not activate the actuator, thus allowing the door to be unlocked.
Am I correct in assuming my observations are correct?
You may be asking why I don't use the FOB, it doesn't work, for years.
So, looking at Rock Autos site, link above, there doesn't seem to be one listed for the drivers side door. Is it universal?
Old 11-18-2018 | 09:02 PM
Here is another scenario: The electronic lock pushes the mechanism a bit farther than the key linkage. Meaning either the linkage is bent or the mechanism needs lubing.
Old 11-25-2018 | 12:59 PM
peterdulux's Avatar
Lock actuator
So going back to the question in my thread, is the lock actuator the same for the left and right front doors?
I think I need to replace my drivers door actuator.
Old 11-25-2018 | 01:20 PM
LF - GM P/N 20791792
LR - GM P/N 20791794
They do not appear to be the same .
Old 11-25-2018 | 01:33 PM
peterdulux's Avatar
According to Rockauto, that is the dock latch assembly, not the electric door lock actuator.
Unless they are one and the same thing.............
Cannot seem to find one for the drivers door.
Old 11-25-2018 | 01:55 PM
tiapetra's Avatar
All in the same assembly
Old 11-25-2018 | 02:09 PM
https://www.ebay.com/itm/2008-to-201...dkvM:rk:2:pf:0
Among others, the listings don't say LF, but the spec does.
Old 11-25-2018 | 06:46 PM
That link does state front door left in the title
Old 11-25-2018 | 06:50 PM
That's what I said, just with .com not .ca
Old 11-25-2018 | 07:18 PM
I see, thanks. It would be easier to select parts if the title was more clear.
