Downshifting problem?
Hi, I am considering buying an HHR but I'd like some info on the way they shift. I am test driving one with an auto tranny and a 2.4 liter engine. When I get the vehicle over 65 mph it will not downshift. Is this normal? Could it be because it has such a small engine or is there some sort of limiter? Sorry if this post is in the wrong forum. Thanks for your help!
No problems like that with my 2.4L! Perhaps there was a specific prob with that particular HHR. Mine takes off like a banshee if I floor it at 60-65.
See: HERE
Also, the HHR has an "I" gear, which is not like most auto trans 2nd, it actually shifts firmer and is more "peppy" running than drive. Additionally, the HHR effectively has a 5-speed auto, as the converter "locks up" whenever you back off the throttle. I can actually hear 5 gears shift when driving.
It's a very fun vehicle - I think you will like it!
See: HERE
Thanks for the reply! The HHR does shift good at 65 and under but I just drove it again and it seems that it will rev too high if it shifts going faster than that. I assume there will be a chip or something coming out to help raise the shift points? I haven't tried the "I" gear yet but I will tomorrow. So far it has been very enjoyable to drive. I like the video as well.
