DRL question
Old 01-24-2012, 01:55 PM
trucky's Avatar
DRL question
I have noticed that different HHRs have different DRLs. Mine has the main headlights on during the day, while others that I see have only the parking lights on in the front. Is there a way for me to change the settings of my DRLs? I retrofitted my headlights with factory HIDs and don't want the bulbs to burn up prematurely because of this.
trucky is offline
Old 01-24-2012, 02:20 PM
brazodoro's Avatar
I know that 2006 and 07's have parking lights only during the day. The later ones, I think, run the headlights. I have gone through quite a bit to find a way to disable the DRL's but to no avail. I changed fuses and tried to get the dealer to help and nothing worked. Just have to turn them off manually every time you start the car. Sorry.
brazodoro is offline
Old 01-24-2012, 02:29 PM
Only 2006 models use the parking lights as DRL's, 2007-2011's use the high beam filaments at 80% of the normal voltage as DRL's. Check out this thread for some ideas to disable the DRL's, some better than others.....
https://www.chevyhhr.net/forums/problems-service-repairs-42/09-drl-auto-lights-disable-18336/
843de is offline
Old 01-24-2012, 03:05 PM
solman98's Avatar
Correct
solman98 is offline
Old 01-24-2012, 03:46 PM
Laco's Avatar
Yes as already stated 2007's and newer use the headlight at reduced voltage for the DRL's. I frankly think the 2006's amber parking light only, looks better, but I suspect there may have been some heat issues with that light on during the daytime.
Laco is offline
Old 01-24-2012, 04:16 PM
db/sb's Avatar
I don't know...we've had ours since new and haven't had to change the bulbs yet.
db/sb is offline
Old 01-24-2012, 05:11 PM
LawDog88's Avatar
My suggestion? Get some good Switch-back LED turn signal lights.. White when not blinking, and amber/orange when signaling..
LawDog88 is offline
Old 01-24-2012, 11:43 PM
trucky's Avatar
That's what I would like to do! (Along with another LED project) but my HHR is an '07... so I would have to find a way to rewire the DRL circuit from the high beam to the FRONT[only] running lights.
trucky is offline
Old 01-24-2012, 11:45 PM
LawDog88's Avatar
I have the same deal with DRL headlamps.. I just notch it forward one when I start the car, and when I want the headlamps on, I change it.
LawDog88 is offline
Old 01-25-2012, 12:28 AM
If ya have foglights, when you turn them on in daytime, the DLR's go off & parks light up, with the fogs..
sleeper is offline
Quick Reply: DRL question
