drl question
Old 12-22-2013, 05:12 AM
hurst2001's Avatar
drl question
I have a 2007 ls and the other day i noticed my tail lights on with my markers on is this normal? I have my lights set to auto but every other hhr i seen only has the headlights low beam and markers on but no taillights...
hurst2001 is offline
Old 12-22-2013, 10:13 AM
Fox Hat's Avatar
My tails are on on DRL could be bulbs out or a mid year change.
I think older vehicles the full set of lights does not come on
Fox Hat is offline
Old 12-22-2013, 12:57 PM
Lucky's Avatar
My 08 tail lamps are not on with the DLR's on. The 06 hhr used the front turn signals as DRL's. In 07 and up the hhr use's the head lamps. My 07 had to have the body controller replaced because the DLR quit working. I never looked my 07 to see if the tail lamps were on. I will have to look tonight when I get home.
Lucky is offline
Old 12-22-2013, 01:11 PM
my 07 LT the tails are off when the DRL's are on! run thru the DIC and see if there is an option to turn lights on or off for the DRL's
Oldblue is offline
Old 12-22-2013, 01:17 PM
Lucky's Avatar
Maybe your headlights are staying on in the day time. I know on my 5spd when you hand the parking brake pulled the DLR's are turned off. Trying your parking brake may help to figure out if the DLR's are on or not.
Lucky is offline
Old 12-26-2013, 12:00 PM
Laco's Avatar
True, on the five speed, pulling the hand brake will kill the DRL's. Its possible that your headlights are on, often at this time of the year, with the sun at such a low angle, I often see my headlights on, during daylight hours. Check the little blue light in the headliner, if its on, your headlights are on, along with all the markers and tail lights.
Laco is offline
Old 12-26-2013, 10:59 PM
Sundance's Avatar
Have a 2010 LS and when installing new LED's in the taillights noticed they are on when DRL's are on. And quite bright (now) too! Should be safer, as they don't seem to be very reflective and are quite small.
Sundance is offline
Old 12-27-2013, 01:41 PM
A) the light on the headliner comes on sometimes without the headlights, I don't remember what the circumstances is, but I tested on my 2008. The light is gone on the 2011, I think it went away in 2009.
B)I noticed today that my tail lights stayed on were on for a few seconds after I stopped, put the car in park, left the engine running. By the time I walked to the rear the lights were on and winked off.
donbrew is offline
Old 12-27-2013, 07:16 PM
Laco's Avatar
Hmmm, as far as the little blue headliner light, I would guess the only time it might be on without headlights, would be if the parking lights were manually turned on. Have to check sometime. Have to watch to see if there are any other times. I have decided I like the headliner light. Its a conversation piece, so to speak. Not surprised it was done away with, though.
Laco is offline
Old 12-27-2013, 11:59 PM
After a year without it, I still look up there at dusk.
I think it comes on at that time that everyone complains about their dash lights going off.
donbrew is offline
Quick Reply: drl question
