Dual Battery System
I do belive that Summit Racing or Quadratec has a kit for a Dual Battery Connection.
Here is one from Quadratec: http://www.quadratec.com/products/17004_200.htm
On a normal work day, my laptop could be on 6-7 hours, with car parked. I connected a solar panel to the battery, (a maintainer) but it does not provide enough input to keep battery from draining, I still have to start the car every couple of hours to prevent draining battery completely. I know this cant be good on the battery.
My battery, just over a year old, was probably neglected when the car was not used for about a year. It does not seem to have much capacity. In addition I don't make any trips over about 3 km to charge it.
However, if the question is simply about a second battery in parallel, that should be doable. There is space for it. You have to secure it. And the computer should not know what you did.
