Engine compatibility
Old 11-22-2017 | 12:33 PM
Craneop's Avatar
Hi, im wondering if there is a good guide somewhere as well. To check which engines are cross compatible? I have a 09 2.2 l parts car. W/ good engine. And a 08 has come up, with a blown 2.2l engine, at a auction site.
i checked part numbers on a gm website. They are not the same, it seem the 09' have flex fuel. Is there a digit i can check in the vin? Do all 09's have flex fuel? Thanks
Old 11-22-2017 | 12:59 PM
aradmahogany's Avatar
Yes and Yes to VIN and Flex Fuel questions. In short, they are not compatible without a bit of work. Not exactly plug and play. You have an "L61 I4" eninge, which was used in many GM vehicles, but they may have different pluming for hoses and such.
Old 11-22-2017 | 01:16 PM
Here is the VIN decoder: https://service.gm.com/dealerworld/vincards/
Note that in most years the HHR is a "light truck".
Aradmahogany needs a bit of clarification: L61 is the non VVT/non flex 2008. LE8 is the 2009 VVT/Flex engine.
If you really want to argue semantics it is an L4 not an I4 (really the same thing).
Eight digit "B" is for LE8
Old 11-22-2017 | 01:27 PM
Craneop's Avatar
Thanks. I will steer away then. At my skill level. Im just looking for a plug and play. I would like to tackle an easy engine swap. As it would be my first time
Old 11-23-2017 | 10:13 AM
Oppsie I misread and thought he had already owned the 08. My bad.
Old 11-23-2017 | 10:22 AM
That's what I figured, just got it bassackward.
twinbin
03-30-2013 03:00 PM
gwizz
05-25-2010 12:13 AM
misterjensen
09-14-2007 09:27 PM
