Engine misfire at idle
Old 08-30-2011 | 11:52 AM
Stuggots23's Avatar
Unhappy Engine misfire at idle
Hello I was wondering if anyone could help me with my problem. I have a 2009 with 60000 miles w/ 2.2. At idle the engine misses fairly bad at times. If I power brake it slowly it will get worse. As I am driving there is no misfire and runs fine. I was thinking a plug-wire but from reading some of the threads it could also be an injector. Any ideas would be greatly appreciated. It also has original plugs and wires. I know the plugs are 100000k but that doesn't mean they go that long.
Thanks
Old 08-30-2011 | 12:06 PM
First step is to take it to an Autozone or someplace like it to have the codes pulled, since its misfiring you will have a code or codes set. Most auto parts stores will pull the codes for free and provide you with a printout of the code numbers and possible causes.
You may need plugs, but 60,000 is a bit early for them to fail. There are no plug wires on an HHR, each plug has its own individual coil located directly above it. You may have a failing injector or other issue which is why I recommend having the codes retrieved. Once you get that done, update us on what turned up and you can get some pointers on what to check.
Old 08-30-2011 | 12:14 PM
Stuggots23's Avatar
Thank You will do I will get back to you
Old 09-06-2011 | 01:51 PM
tpaul's Avatar
I had a similar problem with the 2.4 in my saturn vue. I changed the plugs and boots and the problem went away.
Old 09-11-2011 | 12:38 AM
deliveryman's Avatar
I had a misfire on cylinder 1 but I could not feel it at idle or driving. It was setting off my check engine light though. It ended up being a burnt valve. They had to rework the head, but it is running great now.
Old 09-11-2011 | 09:51 AM
working on it's Avatar
If you check your codes, check them with a live data scanner under the exact condition that you experience the misfire. My '98 GMC had a misfire for the past year only at idle with the A/C on (600 rpm). No misfire with A/C off at idle (650-700 rpm). I had the codes cleared twice before, and only found the problem with a high-dollar Snap-On scanner last weekend. A Bosch single-platinum would misfire under the first-mentioned condition, but no other. Changed that plug from #6 to #4 and the misfire went there. Problem went away with a new (used) plug. The misfire was setting o2 and mixture-rich codes also. One week later, no new codes!
Old 09-11-2011 | 11:03 AM
DaGrinch's Avatar
At how many miles was this, what type engine and what year HHR?
Thanks.
Old 09-11-2011 | 11:12 AM
Thanks.
This was in my 2009 with 180,000 miles on the 2.2 engine. That has been the only problem with the engine so far.
bluwing
10-30-2014 06:34 PM
Shawn
08-21-2014 03:43 PM
BlackknighT
03-08-2014 11:56 AM
flooprigger
08-04-2013 09:58 AM
nx72905
14
02-04-2013 08:54 PM
