engine swap 2.4 to 2.2
Old 06-07-2022, 04:48 PM
Why do people ask a question then argue about the answer. Go ahead do it and keep records and post up a how to.
I don't know how a VIN could match since the engine type is part of it.
donbrew is offline
Old 06-07-2022, 07:53 PM
I didn't look real hard. JEGS has 2.2 for $2455 and 2.4 for $3785. The difference being VVT.
We have a member in LasVegas that rebuilds. At one time he had 2.4 available. you might try him. Fully Machined Zero Mile 2.2 Ecotec Engine - Chevy HHR Network
donbrew is offline
Old 06-13-2022, 07:44 PM
PulpFriction's Avatar
Originally Posted by hayfield
She has another one with a 2.4 in it and would like to have me fix it for her.
What’s wrong with that motor? Is that one also a 2008?
PulpFriction is offline
Old 06-14-2022, 04:24 PM
Hvymax's Avatar
With all of the electronic aggregation I would just build an engine starting at the stock size. These engine's are all pretty similar so what you can do to one you can do to them all.
Hvymax is offline
Old 06-30-2022, 09:52 PM
hayfield's Avatar
update-2.4 motor she wanted to change out had only blown out a spark plug. she thought the the noise was intense enough to warrant a new motor. Fixed old motor with a helicoil and new spark plug so no motor swap necessary. Old motor only has 121K and purrs like a kitten.
hayfield is offline
Old 06-30-2022, 10:07 PM
But, why did it blow a plug? Never heard of that in a modern motor.
donbrew is offline
Old 07-01-2022, 03:17 AM
This movie had an abrupt and unsatisfying ending. Two stars.
Old 07-01-2022, 06:28 AM
Pass the popcorn! Thanks for sharing!
Oldblue is offline
Old 07-01-2022, 08:27 AM
Lonwane's Avatar
I had a Geo Prism that threw a spark plug.
Turned out when the dealer installed it they had cross threaded it and just muscled it in the rest of the way.
New helicoil and new plug (provided by the dealer) fixed the issue.
Lonwane is offline
Old 07-01-2022, 08:49 AM
That’s why I always hand thread in the spark plugs with a piece of fuel hose to start, then still by hand until finger tight with my 5/8 spark plug socket and 6” 3/8 drive extension, then tighten to 15 ft/lbs.
Oldblue is offline
Quick Reply: engine swap 2.4 to 2.2
