Evap canister vent solenoid question
Old 03-29-2020, 08:47 AM
Blownz's Avatar
Okay bought another one has had a code and all else checked out fine and I tapped this on the ground and dirt fell out. New off brand online came with another plug end. One goes into the sensor and other is a red end plug and I have nowhere to plug that into? This is a 2011 HHR 2.4L.
sensor is the exact same except this other plug end?
Thanks for any help.
Blownz is offline
Old 03-29-2020, 08:54 AM
Do you mean it came with a pigtail to adapt from one style connection to the OEM connector, like this?
Oldblue is offline
Old 03-29-2020, 11:20 AM
If you DO mean you have an extra pigtail; it is for 2006-2007 models, they changed the harness connector.
donbrew is offline
Old 03-29-2020, 11:21 AM
Blownz's Avatar
Hey guys. It looks exactly like that picture blue. So I ignore that and just plug stock harness into new sensor?
Blownz is offline
Old 03-29-2020, 11:39 AM
Blownz's Avatar
Acdelco 214-2341 - this must be the correct one I need then for a 2011?
Blownz is offline
Old 03-29-2020, 11:52 AM
Yep, that’s the one....,
https://www.rockauto.com/en/catalog/...solenoid,16992
and don’t forget the discount code!
Oldblue is offline
Old 03-29-2020, 11:56 AM
Amazon says, for through 2010,
Notes:
  • MUST USE T/W JUMPER HARN 19257603
2011 does not have this note.
RJ_RS_SS_350 is offline
Old 03-29-2020, 11:58 AM
The one with the pigtail "fits all" the one without "fits 2008-2011". Just throw the pig tail away.
donbrew is offline
Old 03-29-2020, 12:10 PM
I used that part on my 2011, the OEM harness plugged directly into it, no need for an adapter harness.
Oldblue is offline
Old 03-29-2020, 12:11 PM
Blownz's Avatar
Okay thanks for the help guys. I bought a Standard brand off amazon part number CVS33. Think I will just buy a Acdelco one instead.
Does the other charcoal unit this one part hooks up to ever go bad? I see it’s expensive.
Blownz is offline
Quick Reply: Evap canister vent solenoid question
