Evap canister vent solenoid question
#32
Yes solenoid.. the more I read online it says the purge valve and canister can cause the same issues. Purge throws another code normally from what I keep reading. The stock canister did have dirt it in when I tapped it on the ground so it was bad. The purge I replaced as I suspected it to be the issue first off a week ago from AutoZone. So unless there part is bad somehow then it has to be the canister solenoid. Unfortunately it won’t be till this weekend when I can look over the HHR again. Wish we didn’t have emissions as I would just delete all of it.
#34
Once again ran great this morning. Don do you think it’s the purge solenoid more then the canister since the purge runs off engine vacuum from manifold to me that would explain why once awhile engine bogs then all a sudden frees up and takes off. Didn’t do this till it threw the code.
#37
#38
#39
It’ll still throw a large evap leak code, but if you turn the code off in hpt, you won’t have a code and you’ll still have readiness plus your problem will be fixed
