Factory Alarm
Old 10-21-2009, 07:37 AM
TyroneMD's Avatar
Factory Alarm
Can anyone tell me how to disconnect the factory alarm. both of my remotes stop working and I want to turn off the alarm so that the horn will stop blowing at 5am in the morning everytime I open the door !
TyroneMD is offline
Old 10-21-2009, 08:24 AM
NxlKing2304's Avatar
take it to the dealer and have them fix it? is it still under warranty?
What year is your ride?
NxlKing2304 is offline
Old 10-21-2009, 08:52 AM
unique_w's Avatar
Factory Alarm
There are fuses that may do this but I agree with NxlKing2304 why not bring the remotes to your dealer and have them reprogrammed or determine why they are not working, if you are still under warranty ?
What is concerning is that both remotes are not working, hence maybe the problem is elsewhere ?
unique_w is offline
Old 10-21-2009, 03:19 PM
TyroneMD's Avatar
I have an 06 LT. The remotes stopped at different times. I replaced the battery in the first one and after that it would only unlock the doors and nothing else. the second one just stopped working and when i replaced the battery in that one, nothing worked at all. I know the dealer is gonna want an arm and a leg for a new remote. kinda of tired of dumping money into this car. having the third set of rotors put on this friday because of the shaking problem. I will see if there is a fuse that i can pull to stop the horn from blowing when the door opens. not worried about the alarm. its an 06 with 96,000 miles. if they steal it, they would be doing me a favor (LOL) !
TyroneMD is offline
Old 10-21-2009, 04:28 PM
an08HHR's Avatar
Did you check to see if the solder joint went bad in the remotes? Look at this thread https://www.chevyhhr.net/forums/how-tutorial-library-21/keyfob-cold-solder-repair-22641/
I think if you use the key to lock it and not the interior lock button, then the alarm won't go off when you unlock it with the key.
an08HHR is offline
Old 10-22-2009, 07:57 AM
TyroneMD's Avatar
Thanks, thats exactly what the problem is. The solder joints in the remote !
TyroneMD is offline
Old 10-22-2009, 09:57 AM
ecl
ecl's Avatar
You should be able to go through the menu and deactive your alarm if I remeber right. Dont remeber right of hand but its a combo of two buttons on your cruise switches that takes you to menu, same two to reset the oil life indicator. Scroll through till you find it. Ill take a look at it today and let you know if some doesnt before then.
ecl is offline
Old 10-24-2009, 01:16 AM
The only way to bypass the alarm is not activating it by the above directions.
jx3 is offline
Old 10-24-2009, 02:54 AM
hhrMama's Avatar
Why dont you just buy a new remote, there not that expensive. You can find programming instructions online I think.
hhrMama is offline
Old 10-27-2009, 09:02 AM
TyroneMD's Avatar
I case anyone wanted to know. A new remote is 88.00 plus 40.00 to program from the dealer !
TyroneMD is offline
Quick Reply: Factory Alarm
