a few random general questions
the steering wheel rarely locks itself when i park and shut off the car. only times i see it lock is when its turned a good amount. does it have to be turned a certain amount either way for it to lock?
also, is there a way to have the auto lights NOT come on everytime i unlock the doors from the remote, as well as start the car? i dont like the headlights being on during the day.
thanks!
thanks!
You can set the headlight to not flash when you unlock/lock with the remote in the DIC setup, By holding the info and enter buttons at the same time to enter program mode, then scroll thru options. That is in the "Owner's Manual". The Steering wheel lock is probably due to the "turn the wheels toward the curb" when parking rules in your high school driver's course (that we have all forgotten).
lol yea i figured it was in the manual, i havent had time to read through it yet. i meant to bring it to work tonight to read, and i forgot it at home!!
last question (i know its in the manual, but im curious now while at work)
when im driving, randomly a little yellow + with a circle around it will come on for a second or so above the rpm gauge. what is that?
It's a light that is supposed to tell you when to shift I believe...but I thought I saw before that people said they rarely light up.
The steering wheel is locked when you shut it off.. Just try & turn it, it won't turn far till it locks in.
how about on the back fenders, the clear protectors on the paint, are those only on models without running boards, or should i say, am i safe to remove those when i get some running boards installed?
