First All Disc Panel -- SS material
Heres an update on that Panel
First All Disc Panel... ( SS ) ... Has - Header, Hi-flow Cat, Cat Back exhaust, Koni Adjustable shocks, Gold Line lowering springs, Progressive Sway Bar, Disc calipers, slotted-drilled rotors....
Still more to come....
Heres what the stock brake system looks like. I'm sure you've seen this typical setup
Now the Panel is setup for Disc's in the rear, along with the better suspension components
