First All Disc Panel -- SS material
All you have to do is go down to the parts counter and look up the exploded diagram for the Cobalt SC/SS or the ION Red Line and it'll give you all the part numbers except for those drilled discs and blue pads. Those aren't GM stock parts.
I wonder how well those rear discs work with the stock disc/drum proportioning valve in the master cylinder?
#28
( Use Cobalt its your friend )
And from the pics I've seen in the HHR SS version those rotors are all solid
not drilled/slotted
http://www.crateenginedepot.com/stor...arts-C192.aspx
#29
Thats right.. Use Cobalt SS -- all disc configuration and there you go...
#30
