Fit an Oven in the HHR
As mentioned by the previous 2 posts you need to measure YOUR item and compare it to the measurements of the HHR.
AS far as weight......UNLESS it is a Wolf or designer oven, the car will handle the weight as long as it is distributed properly. For example, I purchased about 700 pounds of stacking wall blocks and carried them in my HHR with no problem. I laid a couple of pieces of plywood on the floor to protect the interior and plastic over the plywood to "catch" any dirt and debris.
And remember, unless you remove the oven from the packing box, you want the measurements of the box. Which depending on the company and their packing requirements, could be substantially different.
