Floorboard install help needed
Old 08-13-2008 | 09:46 PM
Sunrise HHR's Avatar
Picked up my new 2nd addition floorboards from the stealer and went to install and found that the brackets that bolt to the body needed to have holes drilled and tapped. What a pain. Anyway after searching for a metric bit and tap I got one side done before I ran out of day light. Has anyone had this issue? I have an 06 LT
Old 08-13-2008 | 10:41 PM
an08HHR's Avatar
Are you talking about RUNNING BOARDS? Here is a thread from the How To section and nobody seem to have any problem Also read on another forum how to do it and still no one had problems. Here is the thread https://www.chevyhhr.net/forums/show...running+boards
Old 08-14-2008 | 11:01 AM
Running boards install
Sorry ment runningboards. I looked at the other pictures of the install by the female HHR owner and my brackets look different. they do not line-up with any of the existing clip holes. I am assuming there was a design change along the line. I did do the drivers side last evening it took a little to make sure I was drilling and tapping the holes in the correct spot and turned out rather nicely.
Old 08-14-2008 | 12:43 PM
trfindley's Avatar
"When we tried to put in the bolts, all the holes were gone".
Old 08-14-2008 | 12:44 PM
ChevyMgr's Avatar
It appears you have the mounting spots for a first design and your running boards are second design.
Old 08-14-2008 | 01:55 PM
Running boards
Are there plugs to put in the holes from the old clips?
jgoldwood
04-20-2010 09:43 PM
Spawn21
09-19-2009 04:05 AM
goatcheez
07-26-2009 09:24 PM
220
7
04-11-2009 10:42 AM
tcstoy
09-13-2008 09:55 PM
