Fobs/ keyless entry...
Key fob still working excellent.
Question about remote start....after the car is locked by the fob, i can press and hold remote start and the car will crank.....i can repeat....2x.... then it wont crank again for X amount of time then i can unlock it and lock right back with fob.....same thing, 2X....is that normal?
You don’t need to hold the button down until it starts. Just a couple seconds initiates the start sequence, even if you let go a split second before it begins to crank. Definitely let go once it starts to crank. Follow the instructions in the owners manual.
Also, don’t remember if this was already mentioned but certain OBD codes will disable remote start. If the tails flash but it won’t try to start, check for codes.
