Fog light
Fog light
need help on buying aftermarket foglights with harness,relay,wire, and switch for my 2009 LT1. what kind of lights should I buy. where should I buy them and what is the best for the money.
You guys have been a great help to me and I thank you for it.
Do you want fog or driving lights?There are vast differences in the lenses to give either broad,short range coverage(fogs)or narrower but longer range(driving lights).Hellas or Cibies are excellent choices.PIAAs are also good.Just don't buy the ones that use parking light bulbs-they're awful.
well, you cleared up one of my problems.I did not know the difference.now one more question Tony.the parts man at the chevy dealer told me I would need a different fascia to install oem 2009 lamps in my HHR. the HHR fascia with fog lights are different than one without the foglight.that is the reason you cannot buy OEM 2009 lamps for my HHR 1LT. there is nothing to hold the lamp in. will not snap in. I don"t know ?
Tony I do thank you for your help.
The factory fog lights just snap into place. They replace the dummy plugs perfectly.
Here's what I did initially. I later swapped them out for the stock lights and kept the same wiring I installed here.
https://www.chevyhhr.net/forums/show...ghlight=lights
the hhr front fascia is the same with or without fog lamps unless they changed them in 2009? I would check that out with another dealer.
I have a 2009 and the stock fog lights snapped into place just push out the dummy covers and they snap in from behind so you have to pull back the plastic sheild in the wheel well area the hardest thing is getting those little plastic snaps out, I'm trying to find the pig tails now to fit the fog lights when I find them I'll post where I got them John B.
John B. you have saved me a trip to Houston. you have told me what Ineed to know. yes,please keep me updated.I hope you have them.
again thanks
man, I believe when I joined this forum is the best move I have made in years.
again thanks
purple people eater
09-17-2016 01:07 PM
NxlKing2304
"How To" Tutorial Library
04-10-2015 12:23 PM
itschaboykenny
02-17-2008 12:01 AM
