fog light install help info needed
Old 01-21-2018 | 12:26 PM
kustom's Avatar
Thumbs up fog light install help info needed
ok got the ss bumper with fog lights and want to hook them up
i got the ss waterfall with switch and cut wiring
but found same color wire and plug behind my water fall
in my dash for switch
so all looks good there ?
is there wiring / plugs for fog lamps tucked away some were up front ?
were to look if so ?
if not how do i hook up the fog lights ?
ps wean i installed the ss elec seats plug / wiring was under old manual seat
plug and go
same for radio steering wheel contol pluged right in
i also want to install the factory sub woffer any one known if that will just plug in ?
thanks in addvance for your help
Old 01-21-2018 | 01:09 PM
A fog light install thread
https://www.chevyhhr.net/forums/appe...her-way-31160/
Old 01-21-2018 | 04:57 PM
kustom's Avatar
thanks old blue
was hoping for info on factory wiring
but if i don't find that i can hook to low beams
Old 01-21-2018 | 05:03 PM
The switch wiring goes to the BCM, which will need programming) there might be wiring to the bumper. if not you will need to get wires to the relay (which may or maynot be installed). I don't know about the wiring from the BCM to the relay.
Old 01-21-2018 | 05:28 PM
kustom's Avatar
hi donbrew
what is the bcm ? and how do you programing it ?
thanks
Old 01-21-2018 | 06:43 PM
Cat Man HHR's Avatar
BCM is the Body Control Module, which is in the car behind fuse panel 2 and the fog lights have to be programmed by the dealer. I maybe wrong about this but if you have a Tech 2 tool you can do it also.
From what I've seen on this forum a lot of the wiring is in all the cars even thought that option wasn't installed.
The harness behind the waterfall you found could very likely be for the fog lights. Look closely up front and you may find the harness connectors for the fog lights also.
Old 01-21-2018 | 08:41 PM
kustom's Avatar
ok thanks all
i will pull the bumper and see whats there
rommer
03-05-2014 05:44 PM
Kane2727
Mods - Exterior
04-02-2012 11:46 AM
goatcheez
07-26-2009 09:24 PM
220
7
04-11-2009 10:42 AM
Sunrise HHR
08-14-2008 01:55 PM
