Fog Lights
Fog Lights
Guy's I need help on which way to go on installing fog lights in my 2009 1LT.
should I try to go with oem or aftermarket lights and which would be easy to install.also where could I purchase them.
I don't have the talent most of you guys have doing this stuff.
thanks for any help
thanks for any help
Fog Lamps
GM makes use of a relay and a 15 amp fuse for the fog lamps, here is the wiring schematic. The fuse and relay are located in the engine fuse box. Some wiring in the 09 is not the same as prior years. The 06 is in position 53 and 54.
If you go with after market and use a lamp with a 55 watt bulb each bulb will draw about 4 amps hence they should be on a 15 amp circuit and no less than 18 gauge wire.
Guy's I need help on which way to go on installing fog lights in my 2009 1LT. should I try to go with oem or after market lights and which would be easy to install.also where could I purchase them. I don't have the talent most of you guys have doing this stuff.thanks for any help
The search function can be your friend.
https://www.chevyhhr.net/forums/how-tutorial-library-21/do-yourself-factory-fogs-637/
Here is my aftermarket install. I later swapped the lights our for stocks, but kept my aftmarket wiring.
https://www.chevyhhr.net/forums/show...ghlight=lights
october5
19
06-06-2012 01:06 AM
Gsus
06-26-2009 12:56 PM
volcycle
10-12-2008 08:34 PM
