Front Axle nut size
Front Axle nut size
What size socket fits the front Axle nut on the hubs ? I am wanting to check the torque of the axle nut ( 155 ft/lb ) but I cant find the nut size in the book. Need to pick up one if it is larger than what I have
( 1-1/4" - 32mm )
Makes hella noise when braking/turning only, since brake pads and rotors are good, new LCA and all are good, I am thinking the previous owner didnt properly torque the axle nut on the hub, so I am wanting to check that tomorrow morning , just wanting to know if I need a bigger socket than what I have ( I know I had to get one for my wifes van in the past as mine was too small ) so I just wanted to know the size if needed before I pull into the garage and start pulling the wheels. Going to adjust the rear brakes as well.
( 1-1/4" - 32mm )
Remember, no impact guns to remove or tighten these axle gland nuts, it’s real easy to strip out the nut and sometimes the axle itself can be damaged!
Torque the nuts while the car is on the ground with the centre cap removed from aluminum wheels.
