front brake pads and rotors
Old 06-12-2019 | 10:09 PM
JimDaddyo's Avatar
Originally Posted by Cat Man HHR
This is like reading Yahoo news.
Would like to know the link where you bought them.
I don't know how much good it will do you. It's a Canadian site, but anyways...... https://ca.autoshack.com/
Old 06-13-2019 | 11:12 AM
Ron S's Avatar
FYI GM makes a cast iron rotor for the HHRs. The one that comes stock is a composite rotor and that is the one that warps easy. This is from a dealer, these reduce the tendency to warp, about 6 months ago I had the cast iron rotors installed and so far no sign of warping after having been through winter. We will see.
Ron
Old 06-13-2019 | 08:24 PM
My 2LT Panel came with the larger (non-Brembo) discs.. Those with the regular calipers that have a bigger piston than SS makes nice combo..
Old 06-14-2019 | 10:17 AM
Vinnybagodoughnuts's Avatar
Was that done by the factory or someone added them?
Old 06-14-2019 | 04:13 PM
I couldn’t find different part numbers for later panels for rotors or the calliper brackets.
I wonder if your ball joint stubs are 20.5 mm , like a non Brembo SS
Old 06-14-2019 | 08:15 PM
  #26
I'm not absolutely sure, I got it 1 year old, from original owner. But almost no miles.
So, it is what it is.
Old 06-15-2019 | 07:49 AM
  #27
Sleeper, take a photo of your RPO codes in the glove box, and let’s see what your brakes code is.
JM4 would be the ABS 10.86 inch cast iron rotors
JL9 would be from the SS non Brembo 11.6 inch rotors, and rear axle disc brakes
I went thru all the listed rotors and calliper brackets, at the RockAuto site ,all for 2011 HHR, they all pertain to the 10.86 diameter rotors.
Old 06-15-2019 | 08:48 PM
  #28
Blue- I have the Build Sheet ChevyMgr sent to me long ago. It lists the JM4 (4 wheel anti-lock brake system).
So the original owner musta did the swap, cause I do have the SS 11.6" rotors, I checked that way back when I painted the calipers etc.
All these years I just assumed mine came stock with SS rotors.. the Code doesn't list any size, but if I needed parts I would have learned the hard way..
Old 06-15-2019 | 09:20 PM
  #29
comandoed's Avatar
Gotta keep your rear brakes adjusted properly, and make sure your front wheel lug nuts are not over-tightened.
How do I do that?
Old 06-15-2019 | 09:55 PM
  #30
Originally Posted by comandoed
How do I do that?
Read your owners manual, & a torque wrench is best for proper tightening to spec.
Quick Reply: front brake pads and rotors
