Front passenger side splash guards
Old 09-16-2019 | 10:27 PM
1973laguna's Avatar
I want to replace the splash guards on the front passenger side but having hard time , also does the big one go on first ? Thank you
Old 09-16-2019 | 11:00 PM
Are you referring to the Factory style GM splash guards ?
Mine were very simple to install.
Old 09-16-2019 | 11:18 PM
1973laguna's Avatar
Yes the big one doesn’t want to go back in .
Old 09-17-2019 | 08:24 AM
Lonwane's Avatar
I think he is refering to the inner fender wells. I would like to know also as I am going to remove mine soon to do the chain swap.
Old 09-17-2019 | 08:50 PM
The plastic pins come out easily if you get a forked tool under the head of the pin,.. A screwdriver can work as well w/caution.
The pins are cheap off ebay, I get the Mopar ones that the pin head is separate from the body of the fastener. Kinda like wall anchors for house use,..
Old 09-20-2019 | 10:30 PM
bykdmv's Avatar
where did you get your inner finder splash guard from? i ordered one from rockauto and it was a pos. need an original if possible
Old 09-21-2019 | 09:17 PM
Not sure who you are asking ?
Old 09-24-2019 | 09:39 AM
Vinnybagodoughnuts's Avatar
Try a local junkyard.
Old 09-24-2019 | 03:49 PM
1973laguna's Avatar
Passenger side splash shields
On my 2011 Chevy hhr I took off the wheel well splash shields together to the radiator drain plug and now I can’t figure out how they go back on . Please help!
Old 09-24-2019 | 05:34 PM
You already asked that. I think the part you are referring to is the "wheelhouse liner". It should be a mirror image of the other side. Much wrestling is involved.
Arrows point to the FRONT of the car.
If you are really talking about the engine splash shield, you just have to fire what goes under and over what.
