Fuel Eceonomy differences
Old 06-08-2008 | 04:00 PM
mchuntley's Avatar
I am puzzling over something as I try to get the best distance for my fuel bucks.
I drive a 2007 HHR LS, automatic:
It seems that when I run Chevron 87 I seem to get better mileage that Arco 87.
I mean, I could blame it on the techron, but I am not sure if that is it or not.
Thanks,
Matt
Old 06-08-2008 | 09:07 PM
DavidF's Avatar
Around here, the stations did not have to post if they use 10% ethanol, but they will soon have too. So, some stations give better gas mileage than others (10% ethanol drops your mileage a little).
So it is possible for some gas to be better than others...at least in OK.
Old 06-09-2008 | 08:26 AM
NY HHR's Avatar
Speed will have a big difference also. This weekend I traveled (highway and city) for 34.o mpg at a constant 65 mph on the highway and the speed limit in the city.
Old 06-09-2008 | 08:43 AM
shaginwgn's Avatar
Thanks,
Matt
Because Chvron is a top tier gas see https://www.chevyhhr.net/forums/general-hhr-4/official-list-top-tier-gasoline-retailers-9645/
Old 06-09-2008 | 05:19 PM
sp52075's Avatar
yep its true in my 94 Blazer if I g o to arcco or some other cheap gas I get around 14-15 but at sheel or cheveron I would get a steady 16
Old 06-09-2008 | 06:45 PM
ChevyMgr's Avatar
The gasoline that is 10% ethanol is not always just 10%. My feeling is the cheap non-name brand stations mix more. We have measured up to 13% in gasoline before with our new handy dandy tester. More ethanol means reduced MPG. The maximum our cars can take is 15%, after that the vehicle is not going to run very good.
Old 06-09-2008 | 08:34 PM
tim_tenn's Avatar
The Chevron that I fill up at here just put stickers on their pumps announcing that their fuel contains up to 10% Ethanol. I, too, have also felt like I get better gas mileage on Chevron that I do on the Home Depot fuel or Phillips 66 that I sometimes use.
Old 06-09-2008 | 08:39 PM
afs9's Avatar
Matt, Arco is the WORST and made Blackie drive sluggishly! I only went there as it was the least expensive (my sister says it just 'water'). Now I ONLY put Costco regular and Blackie loves it.
The new Costco in Tustin has a gas station--but that may still be far from Costa Mesa (I work at UCI so it's easy to stop in to fill up like I did this morning!).
Say "no mas" to Arco!
@ngelita
Old 06-09-2008 | 11:54 PM
mchuntley's Avatar
Actually, I am thinking of running chevron consistently, I like keeping my injectors clean! Their bathrooms are usually cleaner too!
Old 06-10-2008 | 08:05 AM
Offy's Avatar
!0% ethanol will yield approximately 5% less milage. It has a 2: 1 burning rate
