Fuel leak?
Old 11-04-2020 | 05:21 PM
SullyinCT's Avatar
Fuel leak?
I recently had been noticing a gas smell when I get out of my car. No smell while the car is driving and no actual mechanical issues. I had work done on the car 2 weeks ago (brake system flush, oil change, replacing the control arms and ball joints, and front brake replacement). The last few days I've been seeing a small puddle just in front of the rear wheel on the drivers side. It smells like gas. Could there be a small hole in the gas line in that area? I haven't had any issues with the gas gauge or fuel mileage.
Old 11-04-2020 | 05:56 PM
Yes, very common problem. They tend to rust out under the plastic clip where snow/salt tend to gather.
it can either be cut out and spliced or completely replaced. If you replace one replace both.
Old 11-04-2020 | 05:57 PM
hurst2001's Avatar
you got a rusted fuel line on the drivers side before the rear wheel .. common spot you can patch it with fuel injection hose or replace the whole line .. there are plenty of threads on this just do a search ..
Old 11-04-2020 | 08:46 PM
I had nylon lines put in before mine started leaking...
Old 11-05-2020 | 06:47 AM
PITER88's Avatar
same here, 08 and big leak
Old 11-05-2020 | 08:22 AM
Not a hard job to replace the fuel lines
https://www.chevyhhr.net/forums/how-...follies-62310/
Old 11-05-2020 | 03:40 PM
SullyinCT's Avatar
Thanks all! I’m going to try to replace them myself on Saturday. I’m not very mechanical, so I’m not that confident!
Old 11-05-2020 | 05:18 PM
If you use the nylon or plastic lines it is much easier to maneuver them into place!
Old 11-07-2020 | 11:00 PM
Radco's Avatar
Yes the famous fuel line leak :O Mine was done on my 2011 a few months ago and my son's 2011 last year !
Old 11-08-2020 | 08:04 AM
I think it’s not just the outside of the tubing corroded, but from the inside from, today’s fuels.
jcunningham
Maintenance and Upkeep
17
04-22-2024 09:48 AM
HHR_driver
05-04-2018 09:09 PM
Oldblue
03-14-2018 10:41 AM
guppy
01-18-2018 09:01 AM
Wolfie
10-09-2010 09:54 PM
