Fuel line for 06 2.4
Old 12-08-2021 | 05:53 PM
Krunk's Avatar
I imagine as long as the line is fuel rated, it would pass. My state has no inspections.a
Old 12-08-2021 | 07:05 PM
I’ve had the vinyl lines in the BlackSwan for over 2 years no problems. We don’t have inspections any longer here except when you sell the car .
Old 12-22-2021 | 09:42 AM
SwissHHR's Avatar
A word of warning regarding those AGS PFL255C fuel lines (https://www.rockauto.com/en/moreinfo...24&jsn=8&jsn=8): they definitely don't fit out of the box.
Angles and bends are partially incorrect, connecting pieces don't fit etc. My trusted mechanic (has built his own exhausts, fuel lines and stuff for decades) managed to make it all fit in the end, but it took quite some time and work.
Old 12-22-2021 | 10:32 AM
The metal fuel lines do need to be adjusted to fit , the plastic lines fit ok, you just need to be gentle and patient in routing them from the fuel tank to the injectors fuel rail and the vapour canister to the purge valve up under the hood
QuickDrawMcGraw
GM Recall Campaigns
25
05-09-2019 10:48 PM
budzone
05-16-2018 11:30 PM
Smoke Wagon
03-29-2014 03:31 PM
tim75901
05-01-2011 07:29 PM
sleeper
2.4L Performance Tech
17
10-30-2009 12:43 PM
