Fuel Range ????
I appreciate all the feed back. But it seems that people back east get better mpg's. I was told that fuel in Ca has way to many additives to combat emissions. I did notice that one time when I filled up Yuma Arizona I did get more miles, but assumed nothing of it. I need to figure out to get at least 420miles and not drive like old lady.
Thanks everyone!!
Thanks everyone!!
I usually fill up at 400-415 or so. I always leave 60+ miles on the range so I don't end up walking. That works out to about 29mpg. The longest i have gone is 515 using 14.25 gallons. That is around 36mpg. 87 or 94, no difference by octane.
Your Fuel Range will change and is calcuated from the level of Octane of the fuel added during fill up. Ie: the higher the octane, the higher range from the onboard computer.
Our last trip from Houston to Eufaula, Okla. Filled up with 87 Octane. Computer read 430 miles. Was able to go 417 miles before filling up.
When filling up with 98 Octane computer shows 480/520 Fuel Range.
The fuel you are using may have a high mix of additives. (Corn or Flex Fuel). or something to slow down and stabilize evaporation. That will result in a lower MPG rating.
The first time I used 98 Octane, I filled up with a 1/2 tank of 87 Octane and the range jumped from 420 up to 460 with out driving, just started the enging and recalcuated the (DIC).
Hope this helps.
Hope this helps.
Please show me something, FROM A RECOGNIZED PUBLICATION, that substantiates/supports the HHR can determine the type of fuel used BY PHYSICALLY ANALYZING the fuel.
LOL
Anyway, can we put this to rest already. For mileage, 94 or 87 it dosen't matter. I say it again, I GET BETTER GAS MILEAGE THAN YOU WITH 87 octane. In c-town we have 94 at the pump, I use it sometimes, when its real hot and I'm carrying 3 other people and luggage and I want to show OFF. Other than that its a waste of money.
I want you to buy whatever you want, it's YOUR hhr. But that won't help mileage. Sorry charlie, I've had too many 515+mile tanks to STILL BELIEVE THE HYPE. If your not in an SS and you have NO BOOST, that it is a HUGE waste to get anything but high quality 87.
And please in whatever response to this post, do not use the words KNOCK, SENSOR, RETARD, TIMING, BREAK IN PERIOD, or the like. You will still be wrong.
I have been crusin at an average of 20% greater mpg CITY and HIGHWAY than the sticker since mile 500 (took that long to use the DIC inst mpg) until today at Mile 5342. Still reading 48% oil life.
Slight clarification. The energy content of the fuel (btu/lb) CAN vary with octane, sometimes up sometimes down. High octane race gas with high Toluene content yields better MPG. High percentage of Ethanol raises octane, but lowers energy content, so you really need to know the make-up of the fuel in your state to conclude with certainty that octane does not affect mileage. Cleveland sure got a good one, I can't even come close to his results.
Sorry if I sounded like a "bully". But I absolutely cannot tolerate people that "stretch the truth" and apply it with such conviction that others will pass it on as truth . Absolutely unbelieveable.
Now if I'm wrong about the above assertion, I will apologize AFTER some documentation is provided. And it's still unbelieveable
You have a tune c2vette, so you probably can take advantage of 91+, and probably can't run well on 87, YOU TELL ME, I'm still stock, and lusting after you BSR/HAHN/PPC lol
